Well, I have learned a couple things about trenchers today.
1. Whoever named it a ditch witch used a word that rhymed with their first choice.
2. These things are almost as fun to operate as a front tine tiller.
3. They should have tracks instead of tires.
4. They don't like roots.
5. I should've rented a mini excavator for my yard.
I made some progress soon after I got it home on the section by the pad that I hadn't broken ground on yet. As far as walk behind trenchers, this one is at least a step up from the ones you have to man handle to turn. This one is all hydraulic with independent wheel control.
Then I had to go out for a couple hours. While I was out a brief thunderstorm rolled through to make sure my very moist yard was completely soaked. Then I started trenching toward where I had already started by hand. The tires load up with dirt/mud real easy, and you lose all traction. So, I made it a 6wd trencher.
I would get the strap tight, then go operate the threncher. When I wanted to move back, I would stand on the strap to help pull it while I was trying to back it up. Rinse and repeat every 6 inches. Then came more rain for a few minutes, so I went inside. After a couple minutes it stopped, so I decided to trench on. I tried to maneuver it up where the pipe comes out from the house since it was a little higher up, and potentially less wet. No go. It got stuck, then ran out of gas, then I refilled it and got it unstuck. I was gonna give up for the night, but I wanted to have some sense of accomplishment, so I took it back around to the pad where I had originally started to try to get some of the future solar expansion done. Everything went smooth on the flat ground, but went south when I got toward the sloped section. It's currently stuck where it tried to merge with the other trench. I'll have to get up in the morning and pull it out. Hopefully it will dry up enough to be a little less frustrating tomorrow.
