Pool equipment below pool level, gravity flow when cleaning pump basket/filter
dblaha
4
Escondido, CA
Hi everyone,
I just purchased a home and am new to taking care of a pool. The previous owner was using chlorine pucks for the last ~15 years (I've been reading that these are not the desirable way to go), so I purchased the TF-100 Test Kit and will post levels here soon for advice. The pool does look sparkling clean though so at least there's that.
My question now though is related to the plumbing/equipment. I'm hoping someone is familiar with this equipment and can help me with some concerns. The pool is at a higher level than the equipment, (pool at the top of the hill, plumbing is down below on the side of the hill). It seems to me there is only one inline PVC valve that stops the gravity flow of water when I need to clean the pump basket and filter, unless there is some sort of combination with the pool or spa modes on the control box that can close off the flow of water from the pool.
If I'm understanding this correctly, it worries me a little only having one valve to stop the pool from draining out completely if something busts. I'm hoping I'm just missing something, because half the handle of that valve is broken and needs to be replaced (I'm using the aluminum "T" handle to be able to turn the valve) . I'm not sure how that would be replaced otherwise.
Thanks for any advice.
Also, I'm located in Escondido (San Diego, California), and if there are any recommendations for local service company's please let me know.
Dino
Welcome to TFP.
You have the 3 way valve with the actuator on it that can close off flow to the pump. You may have to remove the actuator and lift the handle over the stops to move the valve to close the pump suction in.
You are seeing why we always recommend ot using ball valves and only use diverter valves. Over time replace your ball valves with diverters.
Oh that's simple, okay thanks that makes sense.
I'm still trying to understand how this all works. On the 3 lines, one is labeled skimmer. I'm assuming one is the pool drain, the other is the vacuum line? Is it obvious which is which?
