I am anticipating my next spring project. We have decided to not invest in a gaz pool heater, or heat pump. We are going to build this winter a solar pool heater system as many have done already. The design could use a pool diverter valve. However the flow rate in the diy solar system will be lower than the one coming out from the pool pump. My idea is to use the valve to let 25% of the flow to take the direction of the solar system to join back the 75% of the flow coming from the pump then in the pool.
It will use this idea but not opening 100% to the heating system: Heater Bypass - Further Reading
Any suggestions or advice ?
