Getting close to signing a contract here in Nashville. Spoke with a few pool builders and this is the one I like best. Wanted to run their proposal by you all to see if there were any red flags. I have asked them about adding a 2nd skimmer. They verbally told me the pump is the tristar 950 and the cartridge filter is the 525sq ft, but I have asked them to add those details to the proposal. Anything else I should change or look out for?
Project Scope
♦♦♦ 15.5 x 35 The Ultimate Fiberglass swimming pool ♦♦♦
♦ One – Piece Composite Fiberglass Shell/ 33 Ton Crane /Freight (life time warranty) ♦ Fiberglass Tanning Ledge with bench seating 14” Depth
♦ Built In Spa with 2 spillovers Edges / 2hp Blower / Actuator for automation
♦ Swim Out Benches With Deep End Steps
♦ Color Range interior pool finish Graphite Gray (Reg. $2500 Free Upgrade)
♦ Built – In Safety Ledge around perimeter of the pool
♦ 605 sq ft Brushed Concrete +451 sf Additional $4,059 (Total 1056 sf)
♦ 102’ Perimeter Belgard Paver Eastwood Coping +$1000 16’ Spa Self Coping (Color TBD) (LifeTime Warranty) ♦ 102’ Perimeter 6” x 6” Standard Pool Tile 32 ft. Spa Tile ($4,260 Free Upgrade)
♦ Hayward Tri-Star VS Pump (3-year Warranty)
♦ Hayward SwimClear Cartridge Filter (3-year Warranty)
♦ Hayward OmniLogic Automation Salt System / iPhone Remote / T-Cell 15 Salt Cell (3-year Warranty)
♦ Hayward Universal HC Series Gas Heater 400,000 BTU (3-year Warranty)
♦ (3) LED Pool Lights/(1) LED Spa Light (3-year Warranty)
♦ (1) standard skimmers
♦ (2) main drains (compliance w/VGB ACT)
♦ (4) directional return jets
♦ 1 Concrete Pump Fees
♦ Auto Fill System ($1000 Free Upgrade)
♦ Up to 8 loads of Gravel Back Fill
♦ Finished Rough Grade Yard / Cleaned and smoothed out ready for top soil or seed and straw
♦ Building Permit w/necessary inspections (Supporting documents are homeowners responsibility)
♦ Electrical wiring of the pool equipment / One Outlet (40 Amps Needed)
♦ Maintenance Equipment... pool alarm, vacuum pole, vacuum hose, vacuum head cleaner, skim net, salt, startup chemicals, used to clean the pool, 1 Construction Pool Clean Up
Total Project Cost $109,868*
Below are options you can add to the base package (Pick and choose any of these items)
Options
~ Upgrade to 1056 SF Permeable Paver Pool Decking/ Belgard Urbana Stone/ 176' Perimeter (Color TBD) + $12,771
~ 82’ x 2’.H Retaining Wall / Face: Mfg Stack Stone (Color TBD) / Cap: 14” x 20” Chiseled Edge (Color TBD) + $11,070
~ Sidewalk / Demo Old Paver / Trench Plumping Lines / 265 SF Permeable Urbana Stone/ 176' Perimeter (Color TBD) + $10,820 ~ Light Package / (8) Low Voltage Wall Lights + $2,500
~ Hayward Aqua Vac 650 Pool Cleaner (3-year Warranty) + $1,600
Note: Hardscapes will be finalizing 3 months prior to digging the pool to ensure products are still available and in stock
Note: Fence will need to be taken down put back up, quote from fence company
Deposit of $10,000 if project is under $60,000 / Over $15,000 / Over $200,000 - $20,000
Project Scope
Options
