I'm looking for suggestions about likely causes for this. The cover engages to close (though it's already closed - hmm) but there is no sound at all when I try to open. The key-switch is fine - I confirmed continuity down both legs - and obviously the system has power since it will try to close. It wouldn't make sense for it to be the magnetic switch since the cover is fully closed so it should be able to open. Unless, the switch is stuck somehow...
The brand is Pool Cover Specialists. It is an electric motor.
