Hi All,
I have an old cement pool with new coping around.
There is no cement joint in between my pool coping. I am now being told this is a problem as it causes water to get in and potentially loosen the coping over time. The original landscaper is suggesting he will joint it now without removing anything but that is really not the proper way as the cement joint won't go all the way down.
Would this be good enough or do I need to remove all the pool coping and joint it properly?
See attached pic.
Thanks so much for your input. I am in the North in Canada so cold winters...
See attached pic.
