Pool coping install
Cindygood
8
Atlanta
Hello All. They just installed our pool coping yesterday and we noticed there is now an area behind the coping where the concrete is still visible (looks approx 2 inches behind the coping all around the pool coping). Is this normal? We just assumed the coping would cover all the concrete. Unfortunately, we live in metropolitan city with small lots, and our impervious coverage is all used up by pool, so, we can't install any more stone to butt up to it, and we were planning on installing sod right up to coping. Obviously the sod won't grow on that strip of concrete. Just wondering if this is how it's supposed to be. Our pool contractor said 'you can put pebbles around it, or we can add grout behind it and slope it down. Doesn't sound aesthetically pleasing to me. Also, does that corner joint look too big? Sorry for all the questions, but this is the best, most helpful forum out there, so thank you all in advance for any advice. See pix.
B.lu
76
New England
I defer to one of the TFP pros but that does not look right to me. I would have expected the concrete to be totally covered, and if the coping wasn't going to be wide enough, the pool contractor should have caught that.
jimmythegreek
In The Industry
Aug 10, 2017
3,515
Morris Cnty NJ
Is there a deck going in or just sod to the coping? Personally I always let my coping overhang the base a hair but for a different reason. Its not wrong, that's fine for adding a concrete deck, but not ideal for sod. grass will always be weak over that concrete and likely die off in summer
ajw22
24,656
Northern NJ
Pentair Intellichlor IC-60
Someone did not do good planning between the width of the concrete collar and the width of the coping.
No inexpensive fix for it now.
jimmythegreek
In The Industry
Aug 10, 2017
3,515
Morris Cnty NJ
Wouldmt be that much work to saw cut down a few inches all around pool amd then chip a square out from the edge to make a deeper void. That would allow some dirt underneath amd with the right grass it wouldnt burn off. Otherwise a 3" paver band behind coping would look good and hide it. Contrasting color bands are popular
Cindygood
8
Atlanta
We were not planning. Deck, just planing artificial turf to the coping. Thanks for your response.
Cindygood
8
Atlanta
Thanks. Thought about a band around it, but wasn't sure how it would look. Good to know contrasting bands are popular
kevreh
500
Annandale, VA
But your photo shows a metal grid thats put down before pouring a concrete patio. Either concrete would cover that edge, or if you go with artificial turf you would build up with sand so the turf is even with the coping.
