Pool Cooling Strategies with Tracking - Fountain, Evening, etc.
Dirk
8,624
Central California
Pentair Intellichlor IC-40
Hmm, didn't follow some of that, but that's OK, I'm slow! It seems to me a shade sail would cut down on your "start up, shutdown" chores. No umbrellas. No sun block (which is better for your pool). Maybe even less covers if that stuff was left under the shade of a sail. No? 'cause I'm with ya, and why I never got a pool cover. I want to just jump in and then get out and walk away. Here's a look that I really like that might cut down on the once-a-year shade sail chore (I put mine up in spring, down in fall, not everyday!). Not one big one, but a bunch of smaller ones (much easier to handle, I put mine up by myself):
I think that looks amazing.
Here's a whole gallery of ideas. This particular company makes a very good product (it's what I own).
And I had to put up a couple poles myself. One is completely hidden in a tree. The other I plan on disguising eventually with some sort of vine, but for now I don't even notice it any more. I can show you how I did it if you're interested. And I would argue that shade sails are way more attractive and much less view-inhibiting than umbrellas.
Anyway, just brainstormin' with ya...
DB-Cooper
424
Austin, TX
Pentair Intellichlor IC-60
Hmm, didn't follow some of that, but that's OK, I'm slow! It seems to me a shade sail would cut down on your "start up, shutdown" chores. No umbrellas. No sun block (which is better for your pool). Maybe even less covers if that stuff was left under the shade of a sail. No? 'cause I'm with ya, and why I never got a pool cover. I want to just jump in and then get out and walk away. Here's a look that I really like that might cut down on the once-a-year shade sail chore. Not one big one, but a bunch of smaller ones (much easier to handle, I put mine up by myself):
Yes that does look great. Those are somewhat permanent, what I was complaining about was more of something that you put up and down. I'm not sure I'd want it to be that permanent given impact to view, etc. Also, you can see even in your picture the large poles surrounding environment. I have some challenges to do that and it would have severe impact to our view so probably can't pull it off.
Dirk
8,624
Central California
Gotcha. Here's the only pole that's visible in my yard. Doesn't inhibit anything. PS. I never cover any furniture. It's all Sunbrella fabric and holds up really well in the sun.
jark87
303
Flower Mound, TX
Jandy Aquapure 1400
Really interesting thread. I’m in the Dallas area and our high/low temp ranges are not as wide. There’s usually less than a 20 degree swing from high to low. I’m guessing that the air is a bit more dry for you.
I’ve been through everything you are attempting and even tried sail shades, but never had them permanently anchored. I anchored them to surrounding trees, which left me constantly worried about high winds snapping a tree into my pool. Every time a thunderstorm would pop up, I was running out to take the sails down - total PITA. The sails also interfered with our diving board and my wife hated them. 😕 I probably could have hidden posts in the trees and professional installation would have improved the look, but I suspect total cost would have rivaled Glacier chiller, which is what I ultimately went with.
Water temp has not exceeded 82 this summer. Was a refreshingly chilly 77 this morning!
DB-Cooper
424
Austin, TX
Gorgeous pool! I also have Sunbrella stuff, but I do think our weather is a bit more fierce here.
Your pole isn't bad at all, with my elevation, the pole would standout like a sore thumb where as yours is hardly noticeable. Do you have a picture from further away, how much of the pool is covered by that?
DB-Cooper
424
Austin, TX
82 is chilly for us.
The interest in the sails for me would be more the shade than the cooling because as stated, we are pretty happy with the water temps right now.
Dirk
8,624
Central California
Not to belabor (but I will!)... There are shade sails and there are "pretend" shade sails, which are just glorified tarps. That latter are usually cheap, don't last all that long and are hung with rope. They flop around even in a light breeze, collect water when it rains and are not particularly wind proof. A true sail is attached to hard anchors (not trees) with steel cable and tensioned up pretty tight. That's what makes them wind-safe. Generally they are made of much higher quality fabric (to handle the tension) and last much longer. They'll have D-rings, not grommets. I'll likely get 15-20 years out of mine. Five years in and I see no sign of wear and tear at all. You don't hang them daily, they go up permanently (or, like me, up and down just once a year). They're not cheap, but you get what'cha pay for...
jark87
303
Flower Mound, TX
Jandy Aquapure 1400
Yep - I get it and good for you in finding a cooling solution! Our trees give us plenty of shade in all seating/congregation areas, but pool still gets full sun most of the day. One other note: we have quite a bit of landscaping around our pool. Mist blowing back from the PVC fountains was slowly killing it and did some damage to a nearby red oak tree. I can’t see any plants in your pics, but wanted you to be aware of what we experienced.
jark87
303
Flower Mound, TX
Jandy Aquapure 1400
Totally get it. I was trying a makeshift route before making the investment in the real thing.
Dirk
8,624
Central California
Thank you, here's the google view. My objective was not temperature relief, just enough shade to keep the sun off me bald head. I have lots of trees and lots of patio shade, so I don't need to cover my furniture and I never use sunscreen. Panels on the roof make up for sun loss from trees. I have no prep to go swimming, I jump in for 10 minutes at a time then out and back under the patios (when the sun is fierce). When I'm in the water I'm mostly under my little triangle of shade. And don't underestimate my climate, supposed to be 106° later today!!
This shot appears to be off season. This time of year the shade is pretty much directly under the sail and patio covers.
jark87
303
Flower Mound, TX
Jandy Aquapure 1400
Too funny. I also have one spot that remains shaded all day. Ironically, it’s the “tanning” ledge.
Dirk
8,624
Central California
Nice setup ya got! Ledge looks like a nice place to relax with a cool drink. Besides, pools are for swimming, decks are for tanning, I always say...
DB-Cooper
424
Austin, TX
What is the going rate for this high-end system?
Dirk
8,624
Central California
Hmm, been a while. Might have been six bills by the time you factor in the SS cable and fittings and posts and footings, etc (I bought the very best I could find). Seems like the sail was in the $400 range. But it's all size and shape dependent, of course. That website will give you a quote, and some fabric samples. They have some of their prices online. Much cheaper galvie hardware would have been fine, I'm sure, but I tend to overkill everything. I only take it down once a year to hopefully double its lifespan, defer some of that cost over more years sort-o-thing.
mguzzy
@Dirk that is cool! nice setup.. If you are looking to manage the temp on the pool I really think cutting sun exposure will make a huge difference. My neighbors pool is in the sun all the time (no trees), is 200 feet away, if that, and its routinely 20 degrees warmer than mine. Mine is has darker plaster than theirs so that is supposed to make it warmer, but mine is in the shade most of the time from all the surrounding trees. So the air temp is the same.. the only difference is the amount of Shade.. BTW. we just had four straight days of 100 degree weather and my pool was 70 degrees this morning.
mguzzy
I just stumbled accross this... its a company that does retractable sun sail type shades. I think they are out of Europe. I have not looked to see if there are what US companies that do these.
DB-Cooper
424
Austin, TX
Final update. With fall making an earlier entry into Austin, I've been having to run the heater the last two weekends. Even with that, low/mid 60s overnight dramatically cools the pool. As stated before, I think the early heat wave in June when days are longest and sun is the most overhead provides the intense heating. Later July/August continued heat is not as significant and despite warmer overnight temps, it's manageable without significant cooling. I've removed the fountain for the season, I think it helps to the tune of a degree or so.
Date:Air Temp HighAir Temp LowAir Temp DiffPumpsFountainsWater Temp StartWater Temp EndWater Temp DifferentialOther
09/20/20836221DayNo86797Heated Pool to 86
09/19/20866719DayNo85805Heated Pool to 85
09/18/20857114DayNo81792
09/17/20917615DayNo82802
09/16/20907416DayNo83812
09/15/20897316DayNo84813
09/14/20927319DayNo86824Heated Pool to 86
09/13/20917417DayNo86824Heated Pool to 85
09/12/20836716DayNo76733
09/11/2065632DayNo74722
09/10/20795722DayNo80755Rained 3" day prior and 1" overnight
09/09/20877710DayNo84822
09/08/20967620DayNo86833
09/07/20947321DayNo85823Ran Heater up two degrees from 83 to 85
09/06/20907218DayNo82802Rained 3" day prior
09/05/2081747DayNo80791Rained 3" day prior
09/04/20867412DayYes82802Rained 3" day prior
09/03/2082784DayYes85832Rained 1" day prior
09/02/20997920DayYes88853Did not run pumps overnight
09/01/201018219NightYes89863
08/31/201008218NightYes89863
08/30/201037924NightYes88853
08/29/201047925NightYes88853
08/28/20998019NightYes87843
08/27/20947618NightYes86833
08/26/20997722NightYes86833
08/25/20977423NightYes86833
08/24/20957520NightYes86833
08/23/20936825NightYes85823
08/22/201027032NightYes87825Rained 2" in the morning
08/21/201007624NightYes85823
08/20/201017130NightYes87825
08/19/201017526NightYes88835
08/18/20977621NightYes88844Cooled down starting around 5pm last night
08/17/201057629NightYes90855
08/16/201067927NightYes89863
08/15/201057827NightYes89854
08/14/201037825NightNo90864Forgot to put fountain up
08/13/201037924NightYes90864
08/12/201027824NightYes89854
08/11/201017922NightYes88853
08/10/201007921NightYes88853
08/09/201007822NightYes88853
08/08/201007624NightYes88853
08/07/201007624NightYes88853
08/06/201017724NightYes88844
08/05/201007723NightYes88844
08/04/201017427NightYes88835Rained at 5pm, got very cold
08/03/201017328NightYes87843
08/02/20977522NightYes87843
08/01/20987325NightYes86833Rained 2" at 4pm previous day, got very cool
07/31/20988018NightYes88844
07/30/20977720NightYes88844
07/29/201017526NightYes88844Rained at 5pm previous night
07/28/20977621NightYes88853
07/27/20957718DayYes86842Ran Spa up to 95 with heater. Hit 95 at 5pm then rain storm came in and cooled to 77
07/26/20937716DayYes86842Ran Spa up to 95 with heater. Hit 93 at 5pm then rain storm came in and cooled to 77
07/25/20997920DayYes88853Ran Spa up to 92 with heater
07/24/201008218NightYes89854
07/23/20997920NightYes89854
07/22/20947915NightYes89854High humdity over night
07/21/20987721NightYes89854
07/20/20997623NightYes89863
07/19/20977621NightYes89854
07/18/201007723NightYes90864
07/17/201007921NightNo89863Forgot to put fountain up
07/16/201017625NightYes90864
07/15/201047826NightYes90864
07/14/201087731NightYes91865
07/13/201067927NightYes91874
07/12/201027923NightYes90873
07/11/201007921NightYes90873
07/10/201007921NightYes89863
07/09/20977918NightYes88844
07/08/20997920NightYes88844High temp went to 88 at 4pm and clouds
07/07/20937914NightYes88844
07/06/201007822NightYes89863Drizzle overnight, high humidity
07/05/201007624NightYes88853
07/04/20997425NightYes89854Put some umbrellas out during daytime
07/03/20967719DayNo88844
07/02/20947915DayNo86833
07/01/20927913DayNo85832
06/30/20897910DayNo85823High humididty
06/29/20867511DayNo86824Rained at 5pm previous night
06/28/20937914DayNo86833High humidity
06/27/20867610DayNo84822Some rain and high humidity
06/26/20947321DayNo85832Some rain and high humidity
06/25/20827210DayNo83812Some rain and high humidity
06/24/20927319NightYes86824
06/23/20927121NightYes87834Overnight low of 77, but 1-2" of rain at 7am lowered to 71
06/22/20967818NightYes88844
06/21/20947717NightYes87843
06/20/20947024NightYes86824Overnight low of 77, but 1-2" of rain at 7am lowered to 70
06/19/20957718NightYes87834
06/18/20947222NightYes86833
06/17/20947222NightYes87834
06/16/20947618NightYes86833
06/15/20946925NightYesN/AN/AN/A
06/14/20946727DayYes86815
06/13/20936825NightYes86815
06/12/20956431DayYes86815
06/11/20936330NightYes86815
06/10/201006931NightYes91847
06/09/201007723NightYes90864
06/08/20957421NightYes90864
06/07/20957421DayNo89863
Dirk
8,624
Central California
Wow, nice work. What a great effort. If you make changes to your cooling (adding a chiller, shade, more/different fountain(s), etc), you'll have this great baseline resource to compare to. Did you come to any other conclusions? Or decide on any specific course of action for next season?
DB-Cooper
424
Austin, TX
We really like warm water. There was only 1 or 2 days that were a little too warm but not too warm to not have a blast. If anything, I’ll dial back my cooling efforts if I see cooler days in the forecast.
88-89 is our perfect water temp so I’m able to mostly control that. The record breaking June heat we had was the real anomaly. The long July/August heat didn’t really bother with the pool temps.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
I only skimmed the thread but got a good look at the pic in operation up in post #2.
If you haven't already modified it, your droplets are too big. Make them smaller, make your fountain "spray" even mist-like, and you will see a dramatic improvement
