It's that time of year in the to start closing the pool in MA. For the past two years I have used a mesh elephant type cover and for the past two years the water has been black with chunks of algae in the spring when I open the pool.
My closing procedure is Make sure all debris is out of pool and pool is clean, blow out and plug all lines. Dump a whole bunch of liquid chlorine in like 4 gallons for 19K pool and cover.
Since we had our coping redone the cover does sag a bit when snow is on it as new coping is flush. So I will tighten up springs for cover. Also the pool gets really full from snow where water is level with top. So all of this might cause the algae problem in the spring.
Thanks
Thanks
