You don't need to test cya as you added enough to get yourself to 30 and you started with 0. So you already know that result. You can double check that on a bright sunny day as the test needs to be performed in full sunlight outdoors.
You've already tested ph and it's fine.
The one to be concerned with is FC. We dosed your cya to 30 so your shock level is 12ppm FC. Test your FC and then add enough bleach to bring you to 14ppm. Repeat the FC test evert 2 hours, or when you can, and redose your chlorine to 14 each time. The more frequently you do it, the quicker it will go. Don't worry about the second half of that test for CC until your pool is looking clearer, it will save you reagent.
To test, fill the cylinder to 10ml, use one heaping scoop of the powder. Water should turn pink if there's any FC, if it stays clear, FC=0. Then drop in r0871 and swirl after each drop (speedstir comes in handy!). Each drop counts as 0.5ppm FC, drop until it's completely clear.
Side note: I see you bought the Taylor test kit with the smaller bottles then the TF... if you use a 5ml water sample each drop counts as 1ppm FC... Save even more reagent. Just make sure you're very precise that it's 5ml... If you're off be even 0.5ml, that means your testing will be off by 10%
