Preface: After replacing several pool covers over the years to tears, etc, we've been closing our pool by doing everything up to the point of covering. Besides the expense of replacing the covers, it also made a mess when trying to get the leaves/debris off before pulling off the cover in spring (above ground pool).
This is the first year, due to extremely warm fall weather, that we have a green pool in December! I've tried removing the leaves from the bottom (we always have them in the past, but water remains blue), but difficult to do when you can no longer vacuum. Will I be able to get rid of algae/green color but dumping tons of bleach (and moving the water around with a pole to distribute), or will I just be wasting money on the bleach? And ideas how to correct this with no filter running?
