Do most of you run your pool cleaner 100% of the time that the pump is running, or do you turn it off when the pool is clean, saving wear and tear on the cleaner? I used to turn my off when the pool is clean, and and use only the main drain and skimmer for water circulation. I did find that algae would start growing inside the pool cleaner hose, presumably since it was baking in the sun, and chlorinated water wasn't circulating through it. I would imagine that could introduce algae into the pool. I assume if I didn't want to run the cleaner 100% of the time, I'd have to take the entire cleaner/hose out of the pool so it dries out?
