Hello @PumpinIron
Quit calling the cleaner you have a "Robot." My robot has heard about this and now appears to have deep depression. I'm going to have to take her to therapy, and you know what that can cost.
Actual robots are powered by low voltage electricity and do not need the pool pump running to work. They are in my opinion, about 10 x better than your suction cleaner, but as @JoyfulNoise points out, not everyone agrees with me.
They look this this... https://www.bing.com/ck/a?!&&p=2c7f...4OUE0N0FBJnZpZXc9ZGV0YWlsJkZPUk09VklSRQ&ntb=1
With the speed you are running the pump, your electricity must be free...
I think that reason your cleaner works sometimes and not at other times is that you are changing the pump speed.
Your schedule is set to run the Pool circuit from 8 am until 7 pm.. This would run the salt cell.
Your High Speed circuit is set to run 7 PM pm until midnight. This is when the cleaner would run. (And due to poor scheduling, your salt cell will not run.)
I suspect that during the Pool Circuit run time, you are manually tuning on the High Speed circuit. When you do this, the cleaner runs and when you don't turn on High Speed, the cleaner does not run well.
