Evening all, 3 years into my pool and thinking that the filter wasn’t sized correctly. 12k gallons, 3hp pentair variable speed pump with a CC100 casing. It’s now leaking due to splitting at the seam by the drain valve on the bottom center. So my question is, do I need to upgrade to a CC150 to handle the pressure? Appreciate and welcome any advice. As a bandaid I’ve got it fixed with plastic JB Weld that can handle up to 4450 psi.
