Thanks a lot. What is recommended to solve permanently? Drain and acid wash? And any idea on how much shld that cost ..rough range? I am currently SLAMMING and noticing 6ppm loss per night.should I continue that or get onto the acid wash process?
Have you used any products with copper in it? Like algaecide, pucks with blue in the name, etc? Do you have a pool heater?
Since you started the SLAM, complete it. Get your water clear and then address the calcium.
It should be rough to the touch and when you
scrape some of it off, it should foam when you put muriatic acid on it. Do all this later.....complete your SLAM now.
