POOL Calulator Help,,
Deajavu1425
Active member
Jul 9, 2017
33
Toms River, New Jersey
Hi, I’m a little confused with what I should add to the pool according to pool calculator. Just opened pool yesterday, had loads of leaves, all clean now. It’s a little cloudy but can I can see drain. I need help with what I
should add.
Here are are my readings:
Water temp. - 64
FC - 1
CC - 0.5
TC - 1.5
CH - 100
TA - 30
CYA - 50
PH - 7.2
Thank you for your help.
proavia
1,772
Chandler AZ
One other point - are you using Pool Calculator or PoolMath?
Pool Calculator is not kept up and is out of date.
PoolMath - available via the button at the top of the page - is current. There is also a PoolMath app available for iOS and Android.
