Hi,
I have been following TFP process since 2014 (when I joined) with the only exception being that I do phosphate treatments to lower my phosphates.
I am having some staining issues with my Skimmer and Vinyl liner and my Pool Builder says it is because I am keeping my Total Alkalinity too low and it should be 80-120 as recommended by pool manufacturers (I have a Latham Liner).
Below are my latest readings and photos of my skimmers (I have steel walls behind liner (assumedly galvanized). I winterize my pool and usually only have to adjust Alkalinity at the beginning of the season when it is low due to rain/snow coming through my safety cover. The gaskets around the supply's turn my fingers black when I touch them (also due to low Alkalinity according to my PB).
My Liner is 8-years old and in the past two years has started showing noticeable fading as can be seen on the bottom of the photo. Open to feedback/suggestions from the experts here. One item of note is that I did not install any type of anode with my SWG and I have an old Hayward Heater.
Build Type: Vinyl
Volume: 16500 gallons
Chemistry: SWG
Latest Test Result Summary:
FC: 6.5 (22 hours ago)
CC: 0.5 (22 hours ago)
pH: 7.8 (22 hours ago)
TA: 70 (22 hours ago)
CH: 250 (1 day ago)
CYA: 50 (1 day ago)
SALT: 3600 (1 day ago)
TEMPERATURE: 65° (1 day ago)
CSI: -0.33 (22 hours ago)
Build Type: Vinyl
Chemistry: SWG
CH: 250 (1 day ago)
CYA: 50 (1 day ago)
