Folks,
I believe this to be some form of Pool Beam failure? This has been going on for some time. The large gap between the deck and the coping spans an area of about 5 ft. Beyond the 5ft the rubberized strip between the deck and the coping is sound and hasn’t moved since being put down 17 years ago.
On the pool water side, the top part of the concrete substrate is actually pushed forward and has taken the tile off.
So…..options….
I’d like to hear from those who have had this issue, what they did to fix it and the rough cost.
Thank you all.
So…..options….
- Fix it before it may crack the pool itself? Ie: It hasn’t finished doing is dastardly work yet.
- Chip the concrete away, make it flush refit the tiles and move on as it’s released the pressure and shouldn’t get any worse.
Thank you all.
