Well, it’s time to take care some issues on my pool and concrete deck.
I decided to drain the pool due to the main drain being plugged and not flowing at all. Just easier to access it. Also, there was a plug screwed into the main drain port in bottom of skimmer. Not sure why it was blocked off. And CH getting up around 1400 at last check. With the Vegas water we have CH started a bit high and it been over 3 years since it was last empty.
I plan on diagnosing the main drain issue first. My plan is to start by trying to clear the line by using a drain bladder from the skimmer port. Then on to a snake if that fails. Any thoughts on my plan?
Now that the pool is empty, I am looking at the plaster and wondering if I should do anything with it. Any expert opinions on my plan of action on that issue? Doesn’t look too bad to me, but may have some calcium deposits.
The next issue is the concrete pool deck. It currently has a knock down texture that has started to fail in several areas and am looking for ideas on how best to repair. I am leaning toward grinding or shot blasting the whole deck and apply new texture/knock down. Or possible painting.
Any thoughts or ideas would be greatly appreciated!
