I've just had amazing success removing iron with polyfill in the skimmer basket. I've been struggling with iron for quite a while, and finally decided to do an AA treatment and then intentionally oxidize the iron again and try to filter. I let the pH get up to about 7.3 post AA, FC up to ~8ppm and the water turned green (earlier than expected). Stuffed the basket with polyfill, and let it go for the remainder of the day and overnight. Next day, the water was noticeably less green and the polyfill was loaded with iron.
I just turned off the pump, lifted the polyfill out as quickly as possible even though I lost some into the skimmer. I then turned the pump back on low speed to pull the loose iron into the cartridge filter. The water i squeezed out of the polyfill was completely black. I dumped that, and hosed out the polyfill few times; it was several flushes before the water started clearing up. It was amazing how much iron was loaded into that material.
I then put the polyfill back into the skimmer and let it filter for another day. By the end of the second day, the water was completely clear blue again. There was a little bit of staining on the floor, but almost non-existent compared to what I started with. I couldn't have been happier (first time I've said that with respect to iron in all the time I've had this pool).
The cartridge filter was also loaded with iron; I also had great success cleaning iron out of that with AA. Just dump a couple tablespoons in a 5 gallon bucket of water, and then soak the iron laden cartridge filter in it. Comes out snow white and good as new - that AA is amazing stuff...
My suggestion for anyone struggling with high iron - give filtering with polyfill a try. Go ahead and push up the chlorine level after an AA treatment and be ready to start filtering as soon as the water color turns. You'll probably get some staining again depending on how much you started with, but you'll remove an incredible amount of iron in the process.
