My Polaris most resembles the 380, but it came with a dual chamber collection bag.
It used to zip around my pool, climb walls, work its way up and over steps, etc. Lately, it moves very slowly, and, if it attempts to climb a wall, will stall a few feet up and just sit their until the backflow (or whatever you call it) kicks in and pulls it away. Then, the process starts all over again.
Also, the back end tends to float off the bottom. Moving the float all the way forward does not eliminate the problem. I took the float completely off, and that seems to help, but it still seems to have little power.
This afternoon, I totally disassembled it. After removing the lower body, I held it over the return outlet that normally feeds the polaris to blow out any possible obstructions in the jets. I did not disconnect the short hoses that lead to the jets, but cannot imagine that they would be clogged.
Put it all back together, tried it, it seemed a bit better, but still slow, still will not climb, still cannot keep the rear end down on the pool floor unless I remove the float completely.
This is my third Polaris, I started with the 280, but upgraded as I grew tired of constantly replacing bearings (especially those that are in the small drive wheel).
Then, I went to whatever the newest one was, similar to the 380, but the upper body was in two parts. Worked fine for years, but finally, the lower body had literally worn away in spots from incidental contact with the pool's floor, walls, and steps.
I still have it, but have not tried it in years.
This newest model is only a few years old, and, IMO, should be working much better at this young age than it is.
I ordered new tires, but doubt that is really the problem.
Any advice on what else I should look at would be most appreciative.
Caruso
Caruso
