Polaris P955 Motor problem?
pmurph
1
Texas
My P955 began tangling its cord last year, and was turning in only one direction. Now, it not only tangles the cord, but stops with error code 10 (connectivity) when submerged. I am concerned that cord is now damaged from the constant twisting. Really want to know why it is turning in only one direction. Is this a motor problem? Controller? There are no damaged gears, other internal mechanical problems.
ajw22
13,083
Northern NJ
Welcome to TFP.
Error code to is a communication error between the cleaner and the control box. Have you removed the cable and checked the connectors for corrosion or bent pins?
Have you tried Polaris Tech Support for your motor problem?
