i NOTICED IT TURNING IN CIRCLES AND FOUND THAT THE GEAR TEETH WERE BENT ON 1 SIDE SO THE RIGHT WHEEL WASN'T TURNING (Crud sorry for caps)
I replaced the "Drive shaft" and now all wheels turn strong
It started working a little better but still turning in larger circles and eventually ending back up with the hose knotted.
It always ends up back by the port on the wall tangled.
I bought new hoses and laid them out straight in the sun so they would relax
I replaced the backup jet because it was always running.
Everything appears to be in working order.
All wheels are new, all floats are solid (No leaks or water in them)
Suction is strong but within 30 minutes of turning it on, I come back to this:
By looking at this setup in the photo below, is there anything glaring that stands out to you. Pool max depth is ~5 feet
Hose is 20 feet. Furthest distance from the port is 20 feet
Note, the "mast" that the hose and float connect to in the photo has also been replaced since this photo was taken. It was in rough shape and I suspected my fiberglass repair might have been a culprit
