Polaris caretaker self cleaning pool pressure issues
poolmitch
10
australia
Hi all,
I’m having some issues with my caretaker self cleaning system and I’ve attached some photos to better explain my issue.
1. I’m getting no pressure to the caretaker valve, about 3psi but the filter is fine.
2. I’ve cleaned everything about 5 times - skimmer box, removed the nozzles and even removed the valve itself and cleaned the small strainer which was relatively clean. The little springs inside the valve looked ok and seemed to pop out fine but I’m not too sure
3. The main gutter appears to not have any suction anymore. I originally thought it could be a blockage but I’ve used a drain cleaner and it appears as though that isn’t the issue
4. The nozzles seem to work ok but quite sporadic and some stay up after it’s off
I wasn’t sure if I had the water running to a wrong pipe or something else?
The photos attached show I have an odd setup as we just moved in - there is an automatic controller that turns the floor cleaner on with the other pump and I’ve played with it a bit manually but it still seems like the same issue…
I was thinking maybe it has something to do with the solar as I have that on standby and can’t seem to work out why that doesn’t appear to be working or it’s not all connected…. By the way, does anyone know if the solar system runs all pumps as the solar is just for the pool. It seems as though when I’ve had it on standby or I can warm the pool my energy bill has gone up.
Sorry for all the questions but it’s driving me crazy and any help
Would be greatly appreciated!’nn
Post several pictures from seferal different angles showing the entire equipmemt pad in each pic so we can see your pad layout and all equipment, valves, pipes, etc.
Is the IFCS your only way to return water to the pool?
Fill out your signature with pool, pool equipment (including manufacturers and model numbers) and test kit info.
This assists us in providing you with help without needing to ask you each time you post.
Sorry about that it’s my first time here and I’ve only had the pool for 8 weeks so I’m learning as much as I can.
A few more images but let me know if you need more info? I’ve done my signature but apologies I don’t know all of the info.
Does this help you at all? I’ll get the model number and send it through asap.
Thank you again I really appreciate it
Pics from a few different angles would help.
First, remove anything that isn't tied down or attached to help provide a clearer view.
We need to see the entire pad in each frame.
You have a lot going on there - looks like stuff was added along the way without consideration of the equipment already there.
Does this help? Sorry I barely have any room either side to take a photo. Thank you again I really appreciate it.
Let me know if you have any questions.
That plumbing is a bit of a rat maze.
In order for the IFCS to properly function, all water from the filter needs to go to the IFCS water distribution valve.
Where do the 2 pipes go that are between the SWG and the IFCS water valve?
What do the other 2 pumps do?
There are two pumps - one seems to do the in floor system whilst the other seems to run the other flow into the skimmer I think.
I feel like it was working fine but somehow I’ve moved something or have an issue and can’t get to the bottom of it. Maybe it’s happened slowly over time. I think it’s odd that some of the pop ups work, some stay on when it’s off and the main drain seems completely bloked? I’ve removed the main drain and cleared it out and I don’t think there is a block.
Is there anyway to test or try something new?
Thanks again guys I appreciate the advice
