- Feb 6, 2015
- 7,813
- Plaster
- CircuPool RJ-45 Plus
Great - just double checking.
Can you feel/see any flow from any of the infloor heads? If they aren't popping up correctly, water may still be passing thru them. Since the infloor heads are your only returns and water is entering the suction side, the return water has to go somewhere.
Be sure both suction and return valves are set to allow all water to come from and be returned to the pool (OFF on both valves pointing toward SPA / the longer handle end pointed towards POOL).
