I have used Polaris 280/380 pool cleaners for nearly two decades, and decided to spring for the sporty new 3900 to start off my Memorial Day holiday pool party: spent nearly a grand with tax with the promise of a rebate
Installed it today: similar to 380 installation: checked wheel timing (33RPM) and everything looked great
for 30 minutes:then the drive wheel fell off
I removed hubcap (5) and saw wheel lock screw (7) had come out: replaced and tightened
same thing happened 30 minutes later
this time I added a stainless flat washer: it has been running for a couple of hours and this may have fixed it: also plan to add a split washer
For $1000.00 this is unacceptable: common engineering practices recommend a split and flat washer (you can see in the design that at least a flat washer is essential but the manual shows only a screw with no washersl)
Tried to call Polaris: no luck getting through
Wife says the 380 worked fine and wants me to return the 3900 if it is going to be problematic: she says the extra money spent is not worth it if the wheel keeps falling off
the 3900 is a step up over the 380 if only the simple stuff had been done properly
I am very disappointed so far and am considering returning it if I see any more problems
