Have I destroyed my booster pump? Polaris 280 is my cleaner. I inadvertently closed the water valve to my booster, but the Polaris was powered on. When discovered(within a day) water was coming out of the pump housing, like a leak, not gushing, but the motor was still running. After stopping the motor, I reopened the valve to allow water to flow like it should. The motor started up, but no pressure of water was causing the Polaris to move. (Side question: how was water coming out of the pump housing with the flow of water cut off?) What to do ?
