My Bestway 14' x 42" Steel Pro™ Frame Pool Set has 1.25 hoses that connect to the pool with a clamp. It did not come with a valve to shut the water off from the pool to the pump system. It's a pita to change the filter or do any maintenance without the valves. So, I want to buy them, but every one I find seems to screw on to the pool. There is no place on the pool to screw onto = it's a hose/clamp. Also, none of the descriptions tell you what size hose they take. I have no clue and they are expensive piece to guess at. How can I convert these valves to use with my system.
I have Intex 2500 GPH Filter Pump & Krystal Clear Saltwater Pool Chlorinator w/ GFCI which uses 1.5 hoses. I had to use converters for my hoses to the pool, but it came with the right sized fittings, so it was no problem.
Any idea what cut off valves and/or converters I can use and how I can make it work? TY
