I am adding a heat pump to my setup today. I have a 3 way going to my solar and a check valve on the return. I rarely bypass it anymore since I no longer have a pool vacuum (upgraded to an electric robot) but its nice to have the option to isolate them/bypass them.
I'm thinking of cutting in the heat pump the same way, after the solar. I'm going to get rid of the frog thing (since I haven't used it since the first year I had my pool) to make room.
I was going to do the same exact thing as my solar, another 3 way valve, and a check valve on the return.
Now for whatever reason I can isolate the heat pump and the solar heaters. Have one on, have both on, or bypass both completely.
Does anyone see an issue with that setup?
