See attached picture.
Green arrow points to plumbing which I believe by passes the heater and returns to the pool.
Blue arrow is linked to the water going via the heater exchange
Red arrow is water coming from the filter and is returning to the pool.
Question;
When I want to heat I open the blue arrow valve. I leave the green arrow valve open as-well.
The pool does eventually heat up but I assume the water is being diverted mainly to the green arrow valve route as it is the lower of the two.
I was thinking to close off the green arrow valve, it should then flow all the water via the heater exchanger - blue arrow
Valve, right? This could heat the pool potentially 50% more quicker.
My concern is if the pressure is too much ... it will potentially damage something?
Should I keep an eye on the filter gauge in this case?
Question;
