Plumbing for SWG
DAB942
668
Space Coast, FL
Good morning,
I was going to install it this morning. When I measured the Circupool 60+, it's about 13.5", which is longer than the tab feeder I have.
So, I'm going to have cut and do some zig zagging. Looking for advice for making the length of the cell.pool.jpg
Maybe use a right elbow our of the 3-way valve to go further right, then a couple left elbows (u-turn) further away to give you move length in the back run? Or you can use their vertical installation kit?
That's what I was thinking, initially. But, after thinking more, vertical will probably be an easier installation with alignment. For horizontal, I'll have to add a coupling after I cut to match height and then aligning the two sides. Vertical might be easier and keep the same footprint. When I replace the heater, I foresee a major re-plumb anyway.
Reactions: Texas Splash
Here's a picture of mine vertically right after I self installed.
