- May 21, 2020
- 32
- Vinyl
- CircuPool RJ-45
I will be adding an in-line SWCG, flow switch, and sacrificial anode to convert our existing pool.
I'm confused as to the existing check valve on the plumbing right before the heat pump. Any ideas as to why this is located here? The documentation I pulled from the heater doesn't show any configurations of pool/spa/heaters that would necessitate a check valve in this position. Maybe at some point there was a bypass loop or isolation valves?
I would certainly welcome any feedback on my proposed install/diagram.
Existing System: Pump > Filter > Check Valve > Heat Pump > Return
Proposed: Pump > Filter > Sacrificial Anode > Heat Pump > Check Valve > SWCG > Return
