Construction of my pool is underway and I wanted to share the plumbing to see if this looks ok. I have a 17x33’ lagoon being built. There are 8 returns, 2 skimmers, and usual dual main drain. I didn’t question all the plumbing before hand as they said they build all these pools the same way and they’re one of the largest pool builders in the region. All plumbing is done with 2” PVC. Their standard build is 1.5” with 2 returns and 1 skimmer so I went for the upgraded one for better circulation.
I’ve attached a pic of the plumbing at the equipment pad and it seems that it’s 2 skimmers into one 3 way valve and the main drain separately into the pump. Then the returns are split from one 3 way valve (one controls 4 returns on each side of the pool) and there’s one more that goes to the water fall feature.
What do you guys think of this? Seems like it could be separated out further to have individual control of returns rather than half the pool at a time and even separate control of skimmers.
