- Mar 15, 2014
- 65
- Vinyl
- Hayward Aqua Rite (T-15)
I finally pulled the trigger and bought a Pentair SuperFlo VS pump to replace my old WhisperFlo, and going to install it today, but wanted to get some expert advice on a couple of things first.
In general, please check my plan of attack below and let me know if it will work, or if you see a better way.
I’ve worked in golf course maintenance all my life and installed/repaired a lot of irrigation pipe/valves/fittings, so I’m very comfortable with gluing and routing pvc, but this is a little different. With 10’s of thousands feet of pipe, 1000+ irrigation heads, and the associated valves and fittings, a golf course irrigation system is never going to be air tight. I think this work needs to be air tight, at least on the suction side.
Take a look at my pictures, you’ll see there are no unions on the existing pump, so I'm going to have to cut and replace one valve and existing fittings. There's not much room for new couplings, and I'd like to use unions in case I ever have to take it apart again. If I glue everything I’ll be digging in the ground to find room to put it back together the next time.
So, here’s my plan.
The SuperFlo is same dimensions as the WhisperFlo, and will drop right in place. The downstream side is easy, it’s the supply side that is going to be tough. The pump comes with unions to connect to my 2” pipe, and I’ll add unions at the other two yellow arrows. Then I’ll replace the T, valve, and 90, between the red arrows. The problem is the union on the pump isn’t long enough room to connect to the T, but too long to add another coupling and nipple. I’m not sure how to handle this without moving the pump back, and changing the straight run into the multi-valve and filter.
First question – How do I make that connection on the supply side of the pump?
Next question - Is it okay to use unions on the supply side of the pump. Am I too worried about it being 100%, completely air tight?
Last question – If I can use unions, what is the best choice? I’ve used a lot of those compression couplings in golf course irrigation repair, and obviously when making changes to this system without any problems, but not sure about using them on the supply side
Any other advice, tips, suggestions, all appreciated.
So, here’s my plan.
