Hey folks, I live in a cold region so freeze is an issue. I just closed my pool 2 weeks ago and I have a nagging question as I am not sure I did a couple of things correctly.. Should I re-plug all my equipment - heater, sand filter, pump - after I drain out all the water? This is what I actually did.
Also, when I blew out my lines (using a shop vac) some water came out of the waterfall, some came out of the jet in the deep end (not much though) and nothing came out of the jet in the shallow end. Should I be concerned?
Thoughts? Thanks!
Thoughts? Thanks!
