Please help with sand filter/pump air problem, I'm a newbie!
shawna2444
13
Hi, I just had an inground fiberglass viking pool installed. The installer hooked the plumbing up to my Hayward 24" sand filter and to the 1.1/2 hp hayward super pump. The problem is that there is a gurgling noise near the sand filter up where the elbow pipe meets the filter. It's pretty loud and if the cascade and the jets are both turned on then the psi only registers at 10 and the needle is really jumpy. If I turn off the jets and leave the cascade on high the psi goes up to about 14 but is still pretty jumpy. The gurgling noise is louder when the jets are on then when it's just the cascade. I've done all I can think of to bleed the air out and it's still gurgling. I don't believe I have any leaks in the plumbing because it's only a week old and the pool seems to be filtering fine. I don't even know what the normal psi should be on the gauge at the pump. I feel pretty overwhelmed with the pool now that the installers have left. I just didn't get much info on how to maintain the pool equipment because I didn't buy it directly from the place I bought the pool. I bought it on Amazon. The water is clear and I think it's filtering fine but I just really need some help with understanding what the psi should be and how to get rid of the gurgling noise. Any help would be GREATLY appreciated!! Thanks!!
Beez
785
Dallas, TX
Just to eliminate a couple of easy answers: Are you sure the water level in the pool is high enough? If you remove the cover of the skimmer and look inside, is there water in it or is it sucking dry?
shawna2444
13
Yes it's high enough, we even throw the hose in once the kids have been in there splashing out water all day. Thanks! It's still gurgling, driving me crazy :)
Bama Rambler
23,391
When you open the air bleed valve on the filter does any air shoot out or is it only water?
Is there any air in the pump strainer basket? Can you see any bubbles under the lid?
Just because it's only a week old doesn't mean you won't have a leak.
The most common places are the skimmer sucking air in (as Beez said) or the lid o-ring of the pump strainer basket. You should probably remove and clean it good and lube it with silicon pool lube.
shawna2444
13
Ok I will try that. Thanks for the suggestions. I can't see any bubbles in the basket, it looks good. We don't have air relief valve on our pump. We have a Hayward 1.5 hp super pump and a Hayward 24" sandfilter. I'll try those things you suggested and get back to you tomorrow. Thank you so much!
shawna2444
13
Just checked with my husband and he has placed an air relief valve on the filter earlier today and he said it is not releasing air only water. Is that good?
Bama Rambler
23,391
It's good that there's no air in the filter but it's not good in figuring out what's causing the noise.
One thing that's puzzling me is the pressure gauge not being steady.
shawna2444
13
We tried the suggestions but still no change. My mother and father in law were in this weekend from out of town. They have an inground pool and they also are puzzled by what's going on with ours. It seems like the noise is coming from the elbow connector at the multiport valve/filter. The needle on the gauge left them confused as well because they said theirs usually stays at about 20 and doesn't jump much. My jumps alot. My inlaws seem to think there is no actual problem but that my pump being 1.5hp and my filter being 24" filter it just may be working really hard and that it's not a problem. I'm not comfortable with that. Any other suggestions? Thanks so much so far!! I really appreciate the help ALOT!
Shawna
Bama Rambler
23,391
Have you pulled the elbow off and taken a look inside it. It sounds like there's an obstruction in it. Maybe a manufacturing artifact that's impeding the flow and causing the noise.
zea3
11,575
Houston, Texas
Have you spoken with the installer to ask it they can check for an air leak at that elbow? Also if you can post a photo of the elbow and your equipment that may help us troubleshoot your problem.
One more thought, when you look in the skimmer basket is the water swirling like you just flushed a toilet? Even a small vortex can draw air into the system.
shawna2444
13
My husband said he can't remove the elbow because it's all glued. It's a 90 degree elbow which he says he worries is the proble and why we couldn't have a different elbow there but he says that is what the installer said needed to be there. The installer hasn't been back out and I intend for him to look at but he is out of town and I can't get a hold of him right now. I seriously don't believe it's an issue with any of the underground plumbing but they are coming to lay our concrete soon and I am hesitant to have any concrete put down until I know what's wrong. The installer is a pretty reputable guy so I know he'll come back out , I'm just caught at bad timing right now.We bought Hayward equipment and he (installer ) did mention he wished we would have gotten the equipment they sell with the pools ( don't know what kind they sell for sure ) because it has 2 inch plumbing and he had to get bushings to connect the 1.5" connections on our pump but he didn't seem like he thought it would be a major problem. He just said the filters that he usually works with have an air relief valve to bleed the air off and ours doesn't. The skimmer seems fine, no whirpool or anything that I can see. Thanks for all the help. I'll check back often and I'll be posting pics soon.
shawna2444
13
Hi, I posted some pics of the equipment if you want to look at them. Thanks so much for your help!
G
Guest
Boy, I really don't like the mess they made with that PVC glue. Looks pretty unprofessional. I would guess some of your glue joints are leaking. I wouldn't accept that in my backyard...
Sorry, not impressed :(
shawna2444
13
no worries I agree it's messy looking right now but he's not done with it so it will be better before it's all over, pool was only put in a few weeks ago. It's not leaking around the glue joints, already tried that but thanks :)
Bama Rambler
23,391
I assume that elbow at the very top of the multiport is where the offending noise os coming from.
I don't doubt it's making a terrible noise. That street el is too tight to be right there. I bet if you replace it with a sweep and reroute your plumbing it'll quieten down a lot.
Bama Rambler
23,391
It could be the problem with the jumping pressure.
Normal pressure is an individual thing. It all depends on your individual system.
