I have an inground pool with a Hayward sand filter that is about 7 years old, and it had no issues until about a week ago. Last weekend, I noticed that the filtration pump was making a strange noise. Upon further investigation, I discovered that the pump was cavitating. When I troubleshooted, I refilled the pump's water reservoir, which caused the pump to work briefly before cavitating again because it wasn't pulling in water from the pool. I disconnected the hose from the pump to the filter, and the pump worked with no issue and with a strong water flow. However, when I reconnected the hose back to the sand filter, the pump started cavitating again. A friend who sells pool parts told me that the problem is the 7-way multiport valve, and I would need to replace the gasket on the inside of the valve assembly or buy a new one to fix the issue. When I took it apart, I noticed that the white gasket on the valve assembly appeared to be worn down. While it's plausible that this is the issue, I wanted to ask for everyone's perspective on what might be causing this issue. Thanks in advance for the help.
