Please help me label Pool Plumbing Lines & Valves
Vados09
16
CA
Please help me sticker label all the pipes correctly. Not sure where to begin.
Can you please post particulars about your pool/Spa? Configuration? Spa Spillover? Water features? Number of skimmers and drains etc. That would help. So would pictures of the pool/Spa.
This looks to be a SPA or water feature circuit:
This is an electrical junction box.
This is an abandoned pump...likely a pressure cleaner pump:
This is the main pool circuit. The pressure/return side valve is currently set to flow water through the chlorinator:
This is a product made by Orbit. No idea what it is or what it does...may have been part of the pressure side cleaner.
This gives you the basics. Without knowing more about the pool/Spa/Features, hard to confirm or validate. Post what you can.
Thank you so much!!!
I have spa spillover, vanishing edge and 1 skimmer
