Thank you in advance!
I have been losing water and realized the leak on the pressure side (I think this is the suction side - right before the pump?) of the pool pump. I have a Hayward variable pump - when I am on the low setting, I don't notice the leak. But when the pump is working hard, the leak is a thin spray. I tried to put JB weld but it did not work. Is this something that I can DIY?
Is there a quick fix I could try? Or do I have to unscrew or replace the joint?
I've fixed small leaks before by sawing the pvc pipe
s.
