But the sump pump I bought is designed to rest on the floor. The pipe is only 1.5" wide...the pump is probably a good 9" in diameter. Maybe there is some manual pump I can find on the interwebs. Also, it is NOT risky to drain a pool as long as the hydrostatic valve next to the main drain is removed or open, right?
