- Jul 21, 2013
- 65,185
- Plaster
- Pentair Intellichlor IC-60
Sounds like you have iron in the water and iron staining.Pool isn’t perfect, but it almost always does this after my old shock method, it’s almost like a yellowish stain where the water is, sometimes only about half high. You can’t scrub it off, no tests show metal, but a bottle of locals stores ‘A+’ takes it off in seconds and it’s perfect. I don’t want to do that yet to see if SLAM fixes it
If you do not remove the iron from the water by draining or filtering it will redeposit on the surfaces.
Iron Fill Water Filter - Further Reading
