Hi everyone, I am a first time poster here at TFP, but have been reading about water chemistry for a couple of years here. Our pool was renovated in the summer of 2017. It was resurfaced with Diamond Brite Midnight blue. Starting towards the middle of last summer we started noticing discoloration of the surface.
This spring when I re-opened, it seems to have spread more. I called my contractor and he believes that it is calcium scaling/nodules. We do have very hard water in this area. PC recommends "hot start"ing the pool, i.e 4 days of sub-6 Ph. He believes this will remove the discoloration. I wanted to get a 2nd opinion by posting here as it also seems similar to the white
I generally succeed at having my pool chemistry in check, never had a green pool. Current readings are:
27K Gallon, in-ground plaster pool.
Calcium Hardness: 280
Ph: 7.5
CL: 2 (working on raising this now after the open)
CYA: 90
TA: 150 (working on dropping this a bit with aeration and lower Ph)
I have posted images. Before making a decision to do the hot start, Id like to get an opinions as to whether this is really the issue especially since my calcium readings dont seem that high to me? Any help is appreciated, especially from OnBalance who seems to have written a lot on the subject of plaster issues.
Ph: 7.5
CYA: 90
