I know I will be asked so I will start with the stats ( I have a Taylor K-2006 test kit) but the numbers below are from Leslie's Pools today:
FC- currently low
CC - currently low
CH - 360
TA - 110
CYA - 50
PH - 7.3
No heavy metals
The issue appears to have developed over the winter, it was like this when I opened the pool this year. The pool configuration is a hot tub with a spill over into the 18,000 gallon SWG pool. When I lower the water and blowout / cap the pipes for winterizing the hot tub and pool at that point are separate bodies of water. I make this point because the pool has the issue, the hot tub does not. The folks at Leslie's were no help, a knowledgeable friend told me to use a wire brush. I would prefer to know what the issue is before trying different things.
I will add that before I knew better I used clorox 6 in 1 shock powder every 1-2 weeks during the swim season. I also used it when closing last year. I keep PH and TA in check with baking soda and muriatic acid. I have switched over the HDX liquid chlorine from Home Depot for the swim season weekly FC pickup.
The plaster should be the dark blue with specks seen in the floor of the hot tub (the walls look black in the photo but are not). The other picture is a step in the main pool, but just about all of the main pool looks whitish. The plaster is quartz plaster.
Any feedback would be appreciated.
Thanks
Bill
FC- currently low
CC - currently low
CH - 360
TA - 110
CYA - 50
PH - 7.3
No heavy metals
Thanks
Bill
