Plaster cracks
Itsbobbyagain
4
Phoenix Arizona
Hi, I drained my pool recently and discovered a few cracks in the plaster. The pool is 25 years old, the plaster is about 2 years old. Do they need attention? If so, how should I repair them. The pool is being filled as I type, but will likely take a few days to get to the level at where the cracks are. Pictures attached.
If the pool is not leaking I would not worry about those cracks. They look like they are on the surface and don't go completely through the plaster.
You can use some e-zpatch plaster on it but the color of the patch will not match.
Thanks! I don’t think they are leaking or anything, just wasn’t sure if they will get worse over time left un-patched.
