Hello, so my water is sparkling clear at all times, but once warmer weather hits (Texas, haha), I start getting that nasty light algae on the walls of the pool. It really doesn't matter on chlorine levels, I can keep it near 10ppm and it still will start when it drops below 4ppm. My ph is fine. My question is I don't believe my pool is of the best plaster quality as the finish is rapidly changing color, calcium spotting, and just seems to be rougher, does a deteriorating plaster finish cause algae to dig it's roots deeper in the pores and harder to control? Pool is appx 8 years old. I did not build the pool. I use liquid chlorine, I use shock, I occasionally add tabs to the feeder so levels don't drop, but tabs of course will raise CYA and we have that ideal at 50.
