Plan to fix PVC threaded joint leak
Wow, TIL! Thanks for the PVC Repair link! I have removed the Teflon tape from the threads. Just confirming my understanding, based on your comments & article, the reason for not using Teflon tap is that it may become easier to over-tighten when Teflon tape is present? The over-tightened state with pump's vibration may lead to cracks in union or deformation of O-rings, I presume? Thanks again guys.
The water is sealed with the O ring and the rest of the union is to keep both sides compressed to each other, keeping the O ring pressured.
Teflon on the threads can crack the plastic nut by creating too much stress on the plastic.
Correct.
Yes. Unions should be hand tightened just enough to hold compression on its O-ring that forms the seal.
Teflon tape on non-union threaded connections can be easier to over-tighten. Overtightening, independent of vibration can lead to deformation of the conection.
On a union, is is the pressure of the threads that compress the o-ring. Teflon tape is used as a sealant. On a union, no sealant is necessary as the o-ring does that job.
Two things that make union fittings hard to use and causes a lot of failures are dirty threads and using the wrong tool to tighten them. Large channel-lock type pliers can easily damage and over tighten the fitting. I've found easiest way to make these work well over and over again is:
  • Clean the threads inside and out with a wet rag until all the dirt is removed. WD 40 can help as a cleaner if there's oily dirt.
  • Clean the o-ring and make sure it's grove is pristine as well. Even small particles of dirt can cause a leak that won't stop 'till you clean it. No matter how tight you get it. Once you get it clean lube it with a small amount of soluble silicone lube. When you tighten if it's not lubed the o-ring can catch in the grove and become distorted. All surfaces need to slide.
  • Use the right tool. A belt wrench is perfect. Use one like this that has gripping tread on the inside of the belt:
  • Don't over-tighten. Snug is all you need.
I keep one of these handy to the equipment pad.
I hope this is helpful.
Chris
Reactions: setsailsoon
Chris
You really only have to hand tighten them. If you problems getting them apart, then a wrench can help. I use a pipe wrench myself, because I happen to have large enough ones laying around.
