Plan Review... New Pool Build in Minnesota. First Time Builder, need your awesome advice!
Aug 11, 2016
9
Rockford
New pool build, most likely ordering from Royal Pool soon. Hopefully! I really need help with lights, does anyone have ideas?
  • STD Chlorine (Not SWG) pool, vinyl liner (I had a previous 16x32 Doughboy that I learned from pool school) hoping for the same luck
  • 20x44 Latham 14 gauge steel panels, Walls are 42" deep with 8' deep end
  • full width open steel top steps, they recommended open top?
  • heavy duty adjustable 12 gauge steel a frame braces
  • 42" deck support braces
  • deep end corner swimout benches on each side
  • APC 365 vinyl cover in light gray
  • 1/8" wallfoam
  • Latham Stardust Blue 20 mil liner
  • 2x Hayward Wide Mouth Skimmer
  • 4x Returns
  • 2x Main Drains
  • Pentair Intelliflo 3 HP Pump
  • Pentair SD80 Sand Dollar Filter
  • Raypak 266k Propane heater
  • Automatic Chlorinator
  • 2" ridgid pvc everywhere with individual home runs for every plumbing fixture
  • LIGHTS????? I am scared by everyone complaining on reliability. I am a gadget person and like the color options but don't know what would work best. We are also installing our pool with the full width steps on the house side so not sure how to deal with the lights and brightness.
I am an avid DIY and have done most things, just not a pool :) I am hoping this will be another fun project. We are planning to do a brushed concrete pool deck to finish things off. Please be as critical as you can! I am an engineer and love the details but am struggling with finalizing things.
Thank you!
Go SWG from the start. Puck chlorinator with a heater will kill the heater, by-pass or check valve or not. Full stop.
With a vinyl liner, I would not install main drains.
Go with the biggest cartridge filter (420 o4 520) and gas heater (400K) you can install. Can you use NG? Propane is *expensie*.
Thanks for the info!
With SWG what would you recommend for a generator? Is everything compatible with it?
I was on the fence on main drains, will the pool still clean good enough without?
Curious why cartridge filter over sand?
I will check into a 400k heater, unfortunately propane is all we have out where we live.
This is my gold standard for DIY builds. He detailed everything so well :
We are well divided on main drains. I use mine frequesntly to brush farm dust instead of vacuuming. They aren't needed for circulation but do come in handy. With a pump about water height, i can also drain the pool just below the skimmer quickly for closing each winter.
Thanks for the info NewDude!
What salt water generator do you have? It looks to be about same size as what we are planning to build.
Pentair IC60, possibly still available with the new IC plus 60s out. It's the age old debate if the tried and true or being the betta tester with the new bells and whistles are a better decision. Like you didn't have enough to agonize over. Lol.
The circupool RJ60+ is also a beast if automation isn't going to be in the picture. You buy the RJ45+ on discountsaltpools and 'upgrade' to the 60 for $10 more. Or circupool usually sells it for a similar price in the end with no sale. Check both if going that way.
Here's another DIY build from one heckuva determined lady
Sand filters are fine. I'd still get the largest you can get.
Sand requires backwash (which removes water from the pool). A large cartridge can likely go the season without backwash. They also filter out smaller particles than sand.
If you do get a cartridge, have them put a 3 way diverter between the pool pump and filter so you can pump to waste.
Filter type is more personal preference.
+1. My PB gave me one when I didn't know nothing about nothing. I didn't use it often but in came so in handy when I did that it was non negotiable when we moved and build another pool.
Vac to waste was huge at opening or after storms. Draining a couple inches of rain was equally nice taking minutes. Like 4. I still would have been untangling the 100 ft extension cord, then digging the submersible pump and hoses out. :ROFLMAO:
The 500 sq ft carts was also non negotiable and I spent hours locating it myself during the shortages. I had web surfing, calls and emails far and wide and probably spent half a work week just on that.
Minn Guy here - you've gotten great advice above. I was a tablet guy for decades, and the life changer was going salt water, and a big cartridge filter. My sand was too small for the pump/pool - so that was a big factor, which I fought for years unknowingly. Went from hours per week, and weeks of nasty looking water, to weeks of staring at the pool with nothing to do except for 15min-1/2 hr "check the chem" time per week. A big plus to the vac to waste - you will appreciate it when closing for the winter, and you have to lower the level some. Ditto on keeping a main drain - it allows you to keep lowering, even when the level is lower than the skimmers.
Thank you everyone for all the great advice! I am going to sideline the pump, filter and heater which I dig into those more and learn about cartridge filters and salt generators. I love the direct to waste idea.
Does anyone have any simple advice on lights? Thanks!
I didn't want to replace expensive LEDs every couple of years so I put the old school 500W bulb in. Then I put a Blue lens cover on it. The link is the multipak. I only wanted blue for $14. Lol.
If i ever open the light up, I'll put one of the LED multicolor Floodlightbulbs in it that are now about $100. (I saw as low as $35) I won't mind replacing that every couple of years. LED technology just isn't up to par. The electronics heat up and fail.
I love this idea because I won't be boxed in. I need to install my lights on the long side of the pool. If I were to go with Amerilite's do I need 2 or 3?
That looks good! I unfortunately can't put it under diving board
I'd say 1. It does just fine the old school way under the diving board. (Shown in blue)
That looks good! I unfortunately can't place under diving board because that would shine at house. Our pool is perpendicular to the house with the deep end is farthest away. I believe I need to put them on the side? I'll keep reading, thank you!
After I typed that it hit me that I can't speak to how bright the LED floodlights are. You may want more of them if not using the 500W with the snap on lens cover.
I don't put much stock on the shining at the house stuff. More often than not, if the lights are on, youre not in that part of the house and/or staring at the pool from it. You're in the pool or by the pool.
Then every window in the house has curtains/blinds if it did happen to be an issue that one time.
Then then we never turn it on anyway because its the skeeterbringer9000. :roll:
Okay so I read a bunch and it seems for the 44 ft long pool, with also the most likely chance that I will be going the LED substitues in the Amerlite housing. I should be going with 3 of them on one side. 1 light placed 5 ft from each end and 1 light placed in the middle. What does everyone think?
I think you're our guinea pig here. I have seen considerably different lumens depending on the brand, but don't know how much I believe the generic brands claims. 3 could be obnoxious or not enough depending on said claims.
I am willing to give it a shot! Thank you everyone for all your help. I decided to go with 3 Amerlite, I am assuming this gives me the flexibility to adjust down the road and also have plenty of light if I switch them to retrofit LED's!
Can anyone help with my drawing review? I was thinking of putting all the lights on the west side (right side) as this side is going to be the main sitting area, and the Deep end would shine lights at the house. Also I remember reading that the skimmers should be down wind usually. At our place we get lots of wind and it always is coming from the West, North West (right side). Should I change where they are vs what they drew? Thank you!
I'm torn on these two. You'd need a 3rd skimmer and 3rd return if using the long wall, or 2 skimmers and 3 returns if shooting lengthwise.
Either way, the top left corner will probably collect the most. It may need to be emptied sooner than if it was balanced. I have next to no large debris so it wouldn't matter for me.
Mine shoots the long way with the wind and does fine at 40 ft, with 2 returns/skimmers. I'd add the 3rd return just in case for 44 ft.
