Use the manual for assembly and takedown. All the rest is just the same baloney sandwich you get at a pool $tore.
Ty. Calcium was not an issue but thanksFor your Intex pool, you calcium is just fine. Do NOT increase it. Only need more in a plaster pool.
Haha ok! Noticed that in the "45 minutes assembly" bitUse the manual for assembly and takedown. All the rest is just the same baloney sandwich you get at a pool $tore.
Store never said not to use bleach, just the manual.Please note that household plain bleach is the *exact same chemical as pool store "liquid chlorine""* The only difference is bleach tends to be slightly weaker.
The pool stores often warn folks not to use bleach as they lose the sale of chlorine products.
Walmart plain bleach seems to be the best deal around right now..... one gallon of 6% for something like 1.77?
Maddie![]()
Christi
Your printed report said low.......and I didn't want you to think it was a problem.
I didn't even pay attention to that. TyYour printed report said low.......and I didn't want you to think it was a problem.
Christi
Thank you all. The only thing I've ever added was chlorine and in the beginning, some baking soda. Nothing more. Oh and tablets in the floAter. Here are my test results. CYA is 4![]()
Christi
Sodium hypochlorite is a chemical compound with the formula NaClO. It is composed of a sodium cation (Na+
) and a hypochlorite anion (ClO−
); it may also be viewed as the sodium salt of hypochlorous acid. When dissolved in water it is commonly known as bleach or liquid bleach.
Lol I get it now. So a gallon of bleach is a buck for a gallon and chlorine is $3 for 2 gallons. If i can use it, I'm in.So your not supposed to use clorine?
Christi
