I have the TF-100 Test Kit, which doesn't include a test for phosphates. I brought a sample of my pool water to the pool store (since I was going there anyway for other stuff), and they tested my water and told me my phosphate level was 2041. Should I add phosphate remover to get rid of it, or should I not worry about it at all? There seems to be conflicting information on this in this forum. For example, this article Phosphate Removers - Further Reading seems to indicate that although keeping your phosphate level low is certainly not required, it is kind of a best practice. Other threads on the forum seem to indicate that you should pay absolutely no attention whatsoever to your phosphate level as long as you maintain proper chlorine levels.
So should I try to reduce my phosphate levels or no?
Here are my test numbers from both my TF-100 test kit (first column) and the pool store test (second column) taken 45 minutes apart:
TF-100 /// Pool Store
FC: 5.5 /// 4.38
CC: 0.0 /// 0.39
pH: 7.8 /// 7.8
TA: 70 /// 98
CYA: 50 /// 57
CH: 350 /// 327
Salt: 4300 /// 3400
Phosphates: N/A /// 2041
FC: 5.5 /// 4.38
CC: 0.0 /// 0.39
pH: 7.8 /// 7.8
TA: 70 /// 98
CYA: 50 /// 57
CH: 350 /// 327
Salt: 4300 /// 3400
