I first slammed towards the end of last fall and the correlation between CYA and sanitizer has changed everything for me. Keeping my pool clean and pretty is no longer a chore, but a fun hobby thanks to you all!!!
Today my water is pretty nice, but a little off from perfect so I took a sample into Leslie's to get some extra readings and make sure mine were close to inline with theirs. (All items not listed were in range and otherwise optimal)
Phosphates
879 ppm - Should I just get up to SLAM level to knock this out, or supplement with a product, say NoPhos? My concern here, is the instructions say the Chlorine level must be 4 or below, but that is out of Target Range considering my CYA is rounding up to 50ppm right now.
Calcium Hardness
148 ppm - It's a bit low and out of range, but not sure if I should add something in to get it up in range. Pool store wasn't super concerned about it. Again, the products say to have Chlorine pretty low to ensure effectiveness and I'm nervous to do that.
Metal Stain
In some years past I would mistake Stain for Algae. Once I recognized, I used the product Stain Free (Citric Acid) and it worked wonders!!! Right now, there is very very faint discoloration in some spots, so I'd like to get ahead of it. It also suggests to get the Chlorine real low to ensure effectiveness, I think 2ppm but I've heard it's affective for other people.
There is a pretty clear theme here, many additives that I may be needing right now ask for low chlorine, but I'm nervous cause I've seen first hand that reeks havoc.
Thanks in advance,
Brad
Phosphates
Calcium Hardness
Metal Stain
Thanks in advance,
Brad
